Anyone put two wlans on two wisms into one subnet?
Feb 25th, 2008
We have two WiSM blades on one C6500 switch. We use WiSMs as DHCP relay pointing to central DHCP. Because of the lack of IP subnets, we want to use one /22 subnets for the two WLANs(same SSID) on two wisms. Anyone tried this? Any problems with this setup?
Overall Rating: 4 (1 ratings)
zhenningx Mon, 02/25/2008 - 14:38
No, not really the AP groups. My senario is as follows:
Say I have WLAN/SSID ABC on controller A of the WiSM 1. The WLAN ABC is assigned with subnet x.y.z.0/24. Now I want to add WiSM 2 to the same CAT6500 chassis. I need to create WLAN/SSID ABC on controller A of WiSM 2 as well. The most important is I want the WLAN ABC on WiSM 2 to use the same subnet x.y.z.0/24. So I will have one subnet across two WiSM modules. Is it ok to do this?
Scott Fella Mon, 02/25/2008 - 14:41
Yes.... you will just need to create a dynamic interface on both WLC for the subnet. Then when you create an ssid ABC, you map that ssid to that dynamic interface you created.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
