Warning message
Shared Line across ATA stations?
Feb 25th, 2008
Can analog phones off the same ATA "share" the same extension? Goald is is someone calls XXXX that both analog phones will ring?
If not, can phone off an ATA be part of a hunt group?
thanks
Rob Huffman Mon, 02/25/2008 - 09:59
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hey Daniel,
Long time, hope all is well with you! You can certainly "split" the Extension and share it over up to about 5 phones (no more due to the REN - Ringer Equivalency Number). This can be done simply with a "Y - splitter" or via actual jumpering at the Cross Connect panel.
Hope this helps!
Rob
UCcomp2007 Mon, 02/25/2008 - 15:44
Hey Rob,
Hope all is well with you in wonderfull Canada. I'm sure your hoping it will start to warm up soon.
I appreciate the quick reply. To be clear, if I just want to share the extension accross the two phones attached to the ATA, I don't need to do any thing special right? These will be SCCP ATA's, so I assume just give them both the same extension in CCM and all is well?
Good to here from you as always.
Daniel
Rob Huffman Mon, 02/25/2008 - 16:24
  • Hall of Fame,
    Founding Member
Hi Daniel,
I have never done this across the ports on an ATA. If I wanted to share the line I would always do it via a more "manual" method (ie: wiring) to save the other port for something else (like a fax). I did spend some time searching ATA config notes and didn't see any restrictions for the method you were looking at using. Give it a go, you can't hurt anything and you always have a fallback :)
Spring is in the air +2 today!
Take care my friend,
Rob
kyiver_voip Wed, 06/16/2010 - 02:18
Hi Daniel,
I know it was a while ago, but at the moment I'm having a similar problem. There is a hunt group which include both DNs of an ATA adapter, and for some reason it doesn't work. When the calls reach this hunt group it's only the first extension that rings, as soon as the call is supposed to ring the second extension in the group it cuts off.
So the question is, if both DNs of one ATA can work in a hunt group at all? Please advice.
Thanks.
Andri
