Clientless SSL VPN - MS Outlook
Feb 25th, 2008
Greetings,
Currently, we have a clientless SSL VPN portal deployed for our remote users running on an ASA5520 with version 8 IOS. Is it possible to perform application redirection for MS Outlook 2003 using a clientless SSL VPN connection? Or do we have to upload/configure the SVC plugin? If possible, we would like to keep the SSL VPN "clientless".
Any information would be greatly appreciated. Thx.
Joe
jsivulka Fri, 02/29/2008 - 13:07
I'd think that it possible to perform application redirection for MS Outlook 2003 using a clientless SSL VPN connection.
As far as I know, RPC over HTTP is nothing more than HTTPS traffic from the client to the RPC proxy server (IIS component in MSFT architectures mostly a front-end Exchange). Once the traffic reaches the RPC proxy , the HTTP header is striped and the RPC proxy forwards the Exchange RPC traffic to the Exchange back-end.
j-shearer Mon, 03/03/2008 - 05:09
Do you know if there is any documentation or configuration examples concerning application redirection for Outlook over a clientless SSL VPN?
Joe
