02-25-2008 12:41 PM - edited 03-15-2019 09:03 AM
I am trying to install the newest firmware (P00308000800) to my 7940, under the default devices it says that it is there, I reboot my phone and the old firmware is still registering on the device.
Any thoughts?
-J
Solved! Go to Solution.
02-25-2008 09:51 PM
enter the new firmware version on the device config page, update, reset the phone
02-25-2008 09:51 PM
02-25-2008 11:10 PM
Ensure that all the files for the firmware are included in the tftp statement. e.g.
tftp-server flash:/C7940-60/P00308000500.loads alias P00308000500.loads
tftp-server flash:/C7940-60/P00308000500.sb2 alias P00308000500.sb2
tftp-server flash:/C7940-60/P00308000500.sbn alias P00308000500.sbn
tftp-server flash:/C7940-60/P00308000500.bin alias P00308000500.bin
Note the alias statement is only required if the files are located in a directory other than the root directory.
Then update Telephone-service configuration includes the updated load statement and remember to create the config files.
E.g.
telephony-service
load 7960-7940 P00308000500
create cnf-files
HTH,
Cheers,
