Rate limiting ftp/www
0rsnaric
I'm trying to rate limit ftp and www traffic out of our 20mb/s connection. The goal is to not let downloads exceed 2mb/s. Here is what I'm using and it doesn't seem to be working (router is a 2811 running 12.3(8)).
access-list 103 permit tcp any any eq www
access-list 104 permit tcp any any eq ftp
int fa0/1
rate-limit input access-group 103 2000000 250000 250000 conform-action transmit exceed-action drop
rate-limit input access-group 104 2000000 250000 250000 conform-action transmit exceed-action drop
rate-limit output access-group 103 2000000 250000 250000 confrom-action transmit exceed-action drop
rate-limit output access-group 104 2000000 250000 250000 conform-action transmit exceed-action drop
I'm not really sure what I should be using for the burst numbers. I simply want to stop ftp or www from pulling more than 10% of the total 20mb/s bandwidth of interface fa0/1
Thanks for any help!
Rick
2 Accepted Solutions
shivlu jain
Level 5
Level 5
Actually burst numbers means that how much you allow for the pump.
rate-limit input access-group 104 2000000 2500 2500 conform-action transmit exceed-action drop
use this because burst always in byrtes. Now the above list says the traffic can burst upto 2.5 Mb.
Also i want to add one thing you should use
access-list 103 permit tcp any any eq 443
regards
shivlu
The inbound traffic resulting from downloading from webpages isn't boud to port 80, but is dynamic. If you want to rate-limit inbound ftp and www you need to expand the (inbound) ACL to
ip access-list 103 permit tcp any eq www any
ip access-list 103 permit tcp any eq ftp any
This is because the reply traffic (inbound) have a static source port (80 for http) but a dynamic inbount port
shivlu jain
Level 5
Level 5
regards
shivlu
HI,
You can use single acl 103
access-list 103 permit tcp any any eq ftp
access-list 103 permit tcp any any eq ftp-data
you can reduce the burst size...like this.
rate-limit input access-group 103 2000000 24000 32000 conform-action transmit exceed-action drop
HTH....Pls. rate all helpful posts...
BR
*aijaz*
Okay, that consolidation looks good. And I see that the burst rates are in bytes.
However...
I have this -
rate-limit input access-group 103 2000000 2500 2500 conform-action transmit exceed-action drop
rate-limit output access-group 103 2000000 2500 2500 conform-action transmit exceed-action drop
And we are still able to peg out the ELA circuit (20mb/s) at 60% with downloads. Only saw 25 packets exceed and get dropped. What numbers should I be using to get a maximum rate of 2mb/s?
Thanks!
Rick
