Agent call avoidance
Feb 25th, 2008
Running IPPC Enterprise 7.X, CAD and 7941's at the agent desk. It looks like some agents have figured out an easy loophole in the system. When logged into CAD and awaiting inbound call to be served to them, all they do is simply go off-hook on the 7941, CAD will go into a talking state, they go on-hook on the phone and then they get dropped back into the queue and CAD resets there state duration back to 0 thus making it impossible for them to be the longest available to receive a call. Any suggestions? Thanks for your assistance!
-D
Overall Rating: 5 (2 ratings)
david.macias Mon, 02/25/2008 - 16:45
  • Blue, 1500 points or more
This is not a loophole, there is nothing that will cause your agents to do work unless they want to. This all comes down to training and management. I recommend you don't change your script, but change your agents.
david
dcscuba23 Tue, 02/26/2008 - 12:29
I will leave that up to management. The other problem is visibility when this does happen. Currently, we do not have a really good way of tracking this behaviour from a reporting standpoint.
david.macias Tue, 02/26/2008 - 12:32
There is some visibility. Depending on how your script is configured. You can look at ASA, average talking time, calls handled, average time in state, etc.
david
dcscuba23 Tue, 02/26/2008 - 14:03
Actually, I think I just figured it out. If I enable "Agent State Trace" in Configuration Manager and run Agent Webview report 06 (Agent State Trace Detail By Events)I can see a " Call Initiated Event" followed by the talking state with an ICM EVENT key value as 0. This value seems to differeniate a talking state that was triggered by an off-hook event on the hardphone and a talking state triggered by an inbound ICM call. I can at least enable a state trace on a per agent basis if management has a suspicion. Thanks for your assistance.
dcscuba23 Tue, 02/26/2008 - 12:18
Thank you for the suggestion. I will take a look at the scripts and see what adjustments could be made.
