shivlu jain Mon, 02/25/2008 - 21:34
  • Silver, 250 points or more
you can do like the given
ip route 10.0.0.0 255.0.0.0 fasetethernet0/0
ip route 10.0.0.0 255.0.0.0 fasetethernet0/1 60
60 is the preference, as you are increasing the pref the route will be less prefered.So it will be your secondary route.
regards
shivlu
guruprasadr Mon, 02/25/2008 - 21:42
  • Gold, 750 points or more
HI,
If it is the floating static routes use can use the increased AD as 200 for secondary Link.
ip route 10.0.0.0 255.0.0.0 fasetethernet0/1 200
Pls Rate all Informative Post
Best Regards,
Guru Prasad R
saimbt Wed, 02/27/2008 - 04:54
On a MEN, having a floating static route can give issues.
MEN connects to the router through a switch which in turn connects to the providers network through fiber. If there is a fiber cut at the provider's end, the connectivity between the router and the provider switch will still be UP and the routing entry for 10.0.0.0 will still be reachable through f0/0
Traffic will never fall back on f0/1
-Sai.
