Multiple multilinks on STM on Cisco 7507 router
Feb 25th, 2008
I have Cisco 7507 router on which previously only one multilink is configured and it is applied to four stm interfaces.Now i want to configure two multilinks and want to apply on bundle of two stm interfaces each.But when I created two multilinks and applied on bundle of two interfaces ,it is observed that only one multilink is showing up at a time. but i want both multilinks UP .
My STM interface P/N is PA-MC-STM-1SMI
Pls give me the soln
bjornarsb Tue, 02/26/2008 - 05:29
to help you we need some more infomation on your current configuration.
BR,
bjornarsb
vaishali.nagpure Tue, 02/26/2008 - 22:33
Attaching sample conf
controller SONET 1/1/0
framing sdh
au-4 1 tug-3 1
tug-2 1 e1 1 unframed
tug-2 1 e1 1 description UNUSED
tug-2 1 e1 2 unframed
tug-2 1 e1 2 description UNUSED
tug-2 1 e1 3 unframed
tug-2 1 e1 3 description UNUSED
tug-2 2 e1 1 unframed
tug-2 2 e1 1 description UNUSED
tug-2 2 e1 2 unframed
tug-2 2 e1 2 description UNUSED
tug-2 2 e1 3 unframed
tug-2 2 e1 3 description UNUSED ---------- SO ON
au-4 1 tug-3 2
tug-2 1 e1 1 description **E1 TO XXXX**
au-4 1 tug-3 3
tug-2 2 e1 3 description UNUSED ----------- SO ON
interface Serial1/1/0.1/1/3/1:0
description **TO xxxx**
no ip address
encapsulation ppp
no fair-queue
ppp multilink
ppp multilink group 1
interface Serial1/1/0.1/2/6/1:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial1/1/0.1/2/6/2:0
description **xxxx**
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Serial1/1/0.1/2/6/3:0
no ip address
encapsulation ppp
no fair-queue
ppp multilink
interface Multilink1
description ** To xxxx **
ip address (IP ADDRESS OF MULTILINK)
ppp multilink
Now i want to break this multilink (4 bundles)
with two multilink(2 bundles)e.g. multilink 1(2 bundles) and multilink 2(2 bundles)
But if i do second multilink(multilink 2) it remains down(shows protocol down for multilink interface and physical interfaces also shows protocol down which are bundeled in that multilink)
Pls suggest
Vaishali
bjornarsb Wed, 02/27/2008 - 01:11
Check that your links correspond to the right
interface on the other end. However this should be straigth forward.
Issue a show ppp multilink on both sides.
Else you could try to debug.
BR,
Bjornarsb
vaishali.nagpure Wed, 02/27/2008 - 02:26
We have confirmed links corresponding to the other end before configuring new multilink.
But still we are facing the problem.
Vaishali
vaishali.nagpure Wed, 02/27/2008 - 07:33
Can we bundle two links one on channel (au-4 1 tug-3 1) and other on other channel (au-4 1 tug-3 2)
And do we need to enable distributed CEF?
Vaishali
bjornarsb Wed, 02/27/2008 - 23:49
Yes you can do as you say.
And distributed CEF has nothing to to about getting your interfaces up up.
Have you tried debub ppp multilink ?
BR,
Bjornarsb
BR,
Bjornarsb
gustavomoreira Wed, 06/11/2008 - 07:01
Hi Vaishali,
It's far from February, but have you already solved this problem?
If not, you may try commands 'ppp multilink endpoint none' or 'ppp multilink endpoint ip ' under the serial interfaces to not conflict endpoint discriminators among different multilink bundles.
Sincerely,
Gustavo Moreira
