02-25-2008 11:40 PM - edited 03-05-2019 09:22 PM
I am having 1 Mbps Link.But in my scenerio perticular one source to one destination consuming 80% of total bandwidth.
I need to allocate 200 Kbps for this source to destination. Or can we bound bandwidth restriction on specific Services,Port,Source and destination.
Solved! Go to Solution.
02-26-2008 04:02 AM
HI,
You can use the QOS on the router.
1. Create an extended acl with source/dest n protocol
access-list 101 permit tcp sourceip/mask destip/mask eq www/any port
2. apply it on the interface with the rate-limit command
int se x/x
rate-limit input access-group 101 200000 24000 32000 conform-action transmit exceed-action drop
Please go thru the following link for more info.
http://www.cisco.com/en/US/docs/ios/12_0/qos/command/reference/qrcmdr.html
Pls. rate if it helps..
BR
*aijaz*
02-26-2008 04:02 AM
HI,
int se x/x
BR
*aijaz*
