routing table
Feb 26th, 2008
1. This is a routing table, what is this network topology ?
C is directly connected, Serial1
C is directly connected, Serial0
R [120/1] via, 00:00:05, Serial1
R [120/1] via, 00:00:07,Serial0
R [120/1] via, 00:00:07, Serial0
2. what does mean?
3. what does mean?
Overall Rating: 4 (1 ratings)
shivlu jain Tue, 02/26/2008 - 00:37 is the loopback ip. is the network address which is directly attached.
R means routes coming from RIP network.
royalblues Tue, 02/26/2008 - 01:02
When you use PPP, the Cisco IOS will automatically create a /32 route for the neighbor by default
Hence you see 2 network statements, one is the /32 address and the other is the attached network
If you want to disable this feature configure the following command under the interface
no peer neighbor-route
