RME 4.0.4 - stoped taking config backup of a device
Feb 26th, 2008
I have LMS 2.5 running on a windows box.
I just noticed that RME (vers 4.0.4 )stoped taking config backups of a router that I have had in my system for a long time ( it stoped on version 314 - lot of config changes on that router ).
I did a "update inventory" and got a failed for the job and reason RICS0001: Internal Error .
Does anyone have any ideas?
regards,
Siggi
Joe Clarke Tue, 02/26/2008 - 09:39
If this device used to work, and now you're seeing the RICS0001 error, then you are most likely seeing a bug that was partially fixed in LMS 2.6 with RME 4.0.6. I recommend you upgrade. If the RICS0001 error persists, then open a TAC service request as this might be a different issue, or it might be an issue for which we have a new patch (currently still in testing).
