cleidh_mor Tue, 02/26/2008 - 06:19
Was it a DHCP address that was given out that caused the problem?
You could simply put an ACL on your user VLAN interfaces blocking that IP.
jorgetomas Wed, 02/27/2008 - 02:08
No, the problen is that in the same Vlan a host (manually) puts the gateway IP, the network is broken.
cleidh_mor Wed, 02/27/2008 - 02:34
In that case, your best bet is probably to use static ARP entries so that a new host coming on to the network with that IP can't create a new ARP entry.
srue Wed, 02/27/2008 - 11:14
you can't tell the person who's 'stealing' this IP to stop doing it?
or shut down his switchport.
