IP Phones Time Clock
Answered Question
Feb 26th, 2008
Hi There,
All my IPCommunicators changed the time clock automatically due the daylight saving, but not the IP Phones.. (79xx)..
How can I fix that ????
Thanks.
Andrei.
Correct Answer by Zin.Karzazi about 9 years 3 months ago
IPCommunicators get the Time from the PC. IP Phones get theirs from the Callmanager, so you need to check if the Callmanager Time is correct!!.
Overall Rating: 5 (1 ratings)
Correct Answer
Zin.Karzazi Tue, 02/26/2008 - 03:27
  • Silver, 250 points or more
andrei.goncalves Tue, 02/26/2008 - 04:11
Man.. Cannot believe that..
Ok.. CallManager was not correct..
Thanks !
Andrei.
