2821 ISR Upgrade for voice Gateway
Feb 26th, 2008
I have got a 2821 router with c2800nm-entservicesk9-mz.124-10.bin IOS.
I would like to upgrade it to manage voice services and connect it to a Call Manager cluster.
Do I just need to uprade the IOS version to a Voice one or do I have also to perform an hardware upgrade ?
Overall Rating: 4 (1 ratings)
Steven Landon Tue, 02/26/2008 - 05:15
the base hardware is fine.
what exactly do you want to do with it?
do you have any voice interfaces? DSPs?
jeremie.boisset Tue, 02/26/2008 - 05:30
I want to use this router for voice.
I will have 2 E1 links, some FXS ports and first about 30 ip phones and later up to 500 ip phones.
I do not necessarely need SRST mode.
About DSP, how do I know what I need ?
Thanks for your help
Paolo Bevilacqua Tue, 02/26/2008 - 10:39
  • Hall of Fame,
    Founding Member
Hi, For 2 E1 links and "some FXS ports", you need a PVDM2-64, then if you have more than 8 FXS ports , and addtional PVDM2-8 (minimum).
