7206 VXR NPE-G2 Boot problem
Feb 26th, 2008
Hi, I have replaced router's processing engine NPE-400 with NPE-G2 processing engine .
The router has c7200p-advipservicesk9-mz.124-15.T3.bin IOS on disk2.
I made a basic configuration. I wrote only hostname on the router and saved this configuration.
When I rebooted the router I get "Would you like to enter the initial configuration dialog?(Yes/no)" message.
The router didn't boot with this configuration. I have checked config-register value. it was 0x2102.
How can I solve this problem?
Thanks in advance.
aijaz802 Tue, 02/26/2008 - 05:44
  • Bronze, 100 points or more
I'm not sure but check...
#dir nvram: you should have startup-config file along with other files.
try to save one more time.... or do
#copy running-config nvram:startup-config
I hope this helps....If so pls rate it..
BR
*aijaz*
obasli Wed, 02/27/2008 - 08:38
I have already tried these options but it didn't solve my problem.
Thanks for your help.
