Connection 2 Operator User
Feb 26th, 2008
We always change the default users and dl extensions - is it possible to change the extension on the operator user for CUC 2.When I try it prompts 'this user is associated with a cucm directory number, some fields may be disabled'
hadbou Mon, 03/03/2008 - 09:56
For Communicator, the new release (2.1) will support BLF for call lists, using that you can see the status of the phones (unknown, onhook, offhook) from directory.
