multiple contexts
Feb 26th, 2008
we are an ISP and we are considering giving managed security services to our customers, the ASA provides up to 50 security context in order to give the customer a virtual firewall.
1- do you recommend this scenario ,
2-what about VPN, the multiple context does not support VPN, so how to give a VPN solution also to the customers
3- will VPN be supported in multiple context soon ?
Thank you
jbayuka Tue, 03/04/2008 - 07:10
  • Bronze, 100 points or more
Multiple context mode does not support the following features:
"Dynamic routing protocols
Security contexts support only static routes. You cannot enable OSPF, RIP, or EIGRP in multiple context mode.
"VPN
"Multicast routing. Multicast bridging is supported.
"Threat Detection
