ASA 5510 and NAT to two internal addresses
Feb 26th, 2008
Does the ASA 5510 allow you to static NAT and external address to more than one internal address?
For example, if host A is not available, the NAT from outside in will go to host B?
Overall Rating: 5 (2 ratings)
abinjola Tue, 02/26/2008 - 08:00
  • Cisco Employee,
nopes..you will get a static overlap error
sadam.kherisat Thu, 02/28/2008 - 00:13
you can use the same outside address for different host with different ports, for example if you have an FTP server do static for 21 tcp port, and 25 tcp port for another server.
ray_stone Fri, 02/29/2008 - 13:45
As per my point of view, you can map only one internal IP with outside IP, it is possible only in the case of differnt ports otherwise for the same port or same servive it is not possible.
onlyabhishek007 Fri, 03/07/2008 - 00:15
if u want to do static nat for one public ip to two internal private ip then its not possible but u can do it for two different ports .
