How Many Dialogic Card?
Feb 26th, 2008
I am looking to integrate Unity 5 with a customer's existing Mitel SX200 PBX in the process of slow migration to a Unified Communication end solution.
The question is I need to have 2 of the Dialogic 12port cards in the unity server.
Does this put me into a 7835 or can I still use a 7825? Documentation is not crystal clear on this, but I am guessing that it has to be the 35.
If someone can confirm this ,that would be great.
Thanks.
Tommer Catlin Tue, 02/26/2008 - 09:51
  • Green, 3000 points or more
It depends on the slots in the 7825. If you want something cleaner, I would do (3) PIMGs to your 7825. As long as you have 24 digital ports open on the Mitel, you should be golden.
