Long Url is blocked
zhiqiang.yan
my customer has a very long url (1160 characters) which is generated by the application. it seems being blocked by the css.
is that a policy in css that will block the long url?
If you're talking about how much of a packet the CSS will look at to match a URL, it is actually based on how many packets
(config) spanning-packets
From Command refrence:
"In some environments, URL, cookie strings, or HTTP header information can span over multiple packets. In these environments, the CSS can parse multiple packets for Layer 5 information before making load-balancing decisions. Through the global configuration mode spanning-packets command, the CSS can parse a maximum of 20 packets with a default of 6.
The CSS makes the load-balancing decision as soon as it finds a match and does not require parsing of all of the configured number of spanned packets. Because parsing multiple packets does impose a longer delay in connection, performance can be impacted by longer strings that span mulitple packets. "
Syed Iftekhar Ahmed
