DHCP Server
Feb 26th, 2008
I have configured the Cisco 3825 router as a DHCP server for leasing an IP addresses to me remote intra network.How many IP address can this Cisco 3825 router can lease?
Thanks and Regards,
S.Venkataraman.
lamav Tue, 02/26/2008 - 08:55
  • Blue, 1500 points or more
The address range is specified in the network configuration line.
The addresses you include, if any, in the ip dhcp excluded-address statement will be excluded from the pool.
Victor
Istvan_Rabai Tue, 02/26/2008 - 12:23
  • Gold, 750 points or more
Hi Venkat,
To add some detail to Victor's explanation:
You need to configure the following, just an example:
conf t
ip dhcp pool 1
network 192.168.1.0 /24
The result of this will be that the DHCP server will be able to lease the number of ip addresses that are within a /24 subnet, i. e. 254.
With a /25 prefix the number of available ip addresses will be 126. etc.
In reality it can be less, as you have already at least one ip address manually assigned in a given subnet: the ip address of the interface of the DHCP relay agent, or that of the DHCP server itself.
Cheers:
Istvan
lamav Tue, 02/26/2008 - 12:36
Hi, Istvan:
I didn't give him the actual commands to enter to configure DHCP because he says he already configured it. :-)
Victor
Istvan_Rabai Tue, 02/26/2008 - 12:40
Hi Victor,
No problem. I just gave it for better understanding of the principle.
Cheers:
Istvan
