Debug IP Packets on ASA
Answered Question
Feb 26th, 2008
I've used the "debug ip packet detail list#" for years on the routers. Is there a similar command on the ASA?
Correct Answer by Richard Burts about 9 years 3 weeks ago
Allyn
Look at the capture command on the ASA. It is pretty neat and I believe you will find what you are looking for in this command. It captures packets flowing through the ASA. It allows you to use access lists to control what it will capture.
Rick
Overall Rating: 5 (1 ratings)
Correct Answer
Richard Burts Wed, 02/27/2008 - 10:58
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Allyn
Rick
Richard Burts Wed, 02/27/2008 - 11:59
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Allyn
I am glad that my answer was helpful. Thank you for using the rating system to indicate that your question was resolved (and thanks for the rating). It makes the forum more useful when people can read a question and can know that they will read a response which resolved the question.
The forum is an excellent place to learn about Cisco networking. I encourage you to continue your participation in the forum.
Rick
