Prevent Pings from outside addresses
Answered Question
Feb 26th, 2008
I want to prevent my border routers from responding to pings and traceroutes from outside addresses yet pass ICMP packets if I'm pinging from my internal addresses.
If I apply this ACL to my interface will it do what I need:
access-list 120 deny icmp any host 39.113.22.150 echo
Correct Answer by Jon Marshall about 9 years 12 hours ago
The access-list is applied inbound to the outside interface so it will stop any echo requests from outside coming in.
But if you initiate a ping from inside the network then the packet that comes back inbound to the outside interface is not an echo request but an echo reply and you are not blocking echo replies with this access-list.
So in short, yes it will allow you to ping out :)
Jon
Overall Rating: 5 (2 ratings)
Jon Marshall Tue, 02/26/2008 - 09:38
access-list 101 deny icmp any any echo
access-list 101 deny icmp any any traceroute
access-list 101 permit ip any any
int fa0/1
ip access-group 101 in
where fa0/1 is the outside interface of your border router.
Jon
rolandshum Tue, 02/26/2008 - 09:39
Will that allow for me to ping out from my internal network? I thought if the destination of "any" then the outside interface would stop all icmp requests.
Correct Answer
Jon Marshall Tue, 02/26/2008 - 09:43
Jon
a.cruea1980 Tue, 02/26/2008 - 11:08
You could also simply use reflexive lists.
ip access-list ext Outbound
permit ip any any reflect ReflexiveList
ip access-list ext Inbound
evaluate ReflexiveList
deny ip any any
Then to apply them to your outside interface:
ip access-group Inbound in
ip access-group Outbound out
That will only allow something back into your network that originated from within your network.
