CUOM 2.01 ip phone monitoring & discovery prerequisite.
Feb 26th, 2008
Hi to all.
I want ask you some informations about CUOM prerequisite.
If I have a very large network infrastructure with a lot of switches and also not cisco devices, may I have to configure the SNMP read only Community and the CDP on ALL switches, or only on the first switch where CUOM is attached on and on the last switch where the IP PHONES are attached??
I have the following enviroment:
1]CUOM 2.01 with SP1 and all cisco patches for 2.01 release, on windows 2003 standard edition R2.
2]CCM(call manager) linux version 6.0.1.2000-3
3]The CUOM monitor and discovery correctly the CALL MANAGER (adding http credential and snmp RO community)
4]The CUOM monitor and discovery the FIRST and LAST cisco switch on which SNMP community & CDP are enabled.
5]The ip phones models are supported.
The problem is that the CUOM doesn't discovery and add to monitoring the ip PHONES that are attached to last cisco swicth.
So I don't understand HOW the CUOM discovery and add the ip PHONES.
Does the CUOM add the IP PHONE BY CALL MANAGER or BY swicthes??
May I have to enable SNMP and CDP on ALL switches/routers ?
Thank you in advance.
Rob Huffman Wed, 02/27/2008 - 06:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Nino,
Yes, CDP and SNMP need to be enabled :)
If Operations Manager is going to discover the network through an automated
discovery process, then CDP should be enabled on all the Cisco devices.
From this good doc;
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6491/ps6705/ps6535/prod_white_paper0900aecd8046fe82.pdf
If CDP is not enabled on a device, Operations Manager cannot perform an automated network discovery and cannot gather information about Cisco IP Phones connected to these devices.
For Operations Manager to manage and monitor devices successfully, the following conditions should be met:
SNMP v3 credentials1 or SNMP v2 read community string must be configured on each device.
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6491/ps6705/ps6535/ps7121/prod_white_paper0900aecd8067e2e6.pdf
Hope this helps!
Rob
ninosalvati Thu, 02/28/2008 - 03:24
Hi Thnak you for replay.
Yes I know the requisite.
Because for security & management issue We can't enable CDP on all switches/router.
So I added manualy to DCR, the first(CUOM attached) and the last cisco swicthes(IP PHONES attached) and They have SNMP and CDP enable.
So i think that it could be enough for IP PHONES discovery to works right.
I dont believe that CISCO say that "WE MUST enable CDP and SNMP on ALL DEVICES of my network."
I don't understand if is necassary for ALL or only for particular/strategic/special devices.
Thank you
spaladug Thu, 06/05/2008 - 23:40
Phones are discovered by adding the CUCM into CUOM. If the phones are registered to a CUCM already being monitored by CUOM then to troubleshoot see if the phone shows up in the snmpwalk of ccmphonetable (.1.3.6.1.4.1.9.9.156.1.2.1). The only reason we ask that CDP is enabled on the switch is if you do a discovery by CDP hop count or you want the switch information to show in the phone report (switch ip, phone port, etc.). If you want the switch information to show in the phone report then you have to have CDP enabled on the switch and add the switch into CUOM.
