vlan number which is more than 1024
Feb 26th, 2008
I am testing the voip stuffs. we used many vlans for data,like 200. I want to just add digit "2" to the data vlan, and then get voice vlan number "2200". this way is easy for maintenance. Because everybody are familar with the data vlans.
the first issue comes out, I need open spanning-tree extend system-id in 6513switch. I am worried about whether has some potential risk or limit if I use the extended vlan number which is more than 1024?
Appreicaite your prompt reply...
hadbou Mon, 03/03/2008 - 13:59
  • Bronze, 100 points or more
Extended (VLAN numbers up to 4096) was first supported on the Catalyst 6000 series in CatOS 6.1(1), and on the Catalyst 4000 series in CatOS 7.2(1). When attempting to add an extended-range VLAN, one of the following messages is displayed (depending on the version of CatOS software):
An example for software version 7.3(2) is as follows:
Switch> (enable) set vlan 1040
VTP advertisements transmitting temporarily stopped,
and will resume after the command finishes.
Cannot set vlans in extended range.
Reduced Mac Address feature is disabled in NVRAM.
Switch> (enable)
An example for software version 6.1(4) is as follows:
K-4003 (enable) set vlan 1040
VLAN Trunk Protocol (VTP) advertisements transmitting temporarily stopped,
VLAN number must be in the range 1..1005.K-4003 (enable)
The following example shows how to enable MAC address reduction and create an extended-range Ethernet VLAN:
Switch> (enable) set spantree macreduction enable
MAC address reduction enabled
Vlan 1040 configuration successful.
vocitynet Mon, 03/03/2008 - 14:15
for 6500switch, I am using version of 12.2(33)SXH, combined catos into one IOS. I didn't meet the problems like macreduction. what i did just go to spanning-tree and enable the "spanning-tree extend system-id".
