Coverage Maps
Feb 26th, 2008
I know in pre-4.x WCS, the coverage maps didn't take into consideration AP's on floors above or below - has this been addressed in 4.2 or 5.x?
Also, are the 1131 AP's supported in an upright orientation instead of just the ceiling mount orientation?
irisrios Mon, 03/03/2008 - 14:00
As far I know this feature is implemented in RRM to determine the Channel and power assignment. But there is a proposal underway to impelment this feature.
sabhasin Sat, 03/08/2008 - 19:53
FWIW, RRM is fully 3-D aware since all it cares about is how an AP (radio, to be precise) hears its neighbors. Re: 1131 orientation - it makes most sense to mount these on the ceiling given the antenna radiation pattern that these have. We've seen a few sites mounting them on the walls/pillars/etc but it doesn't make much sense unless you have a very specific requirement. Alternatively, you can consider the 1242s which have several mounting options (with external antenna support).
plandobait Tue, 03/11/2008 - 05:40
Thanks for the info. The 1131's will be used in the office area's and mounted in an upright position on top of file cabinets. >.<
The 1242's will be used in the manufacturing area's.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
