Remote Access VPN
Feb 26th, 2008
Can you have both ssl vpn enabled and IPSEC on the same interface. I can not get the IPSEC client to configure
Fernando_Meza Tue, 02/26/2008 - 14:13
Sure you can .. that is a pretty standard set up.
If you are using an ASA .. just follow the wizard. Then it is just a matter of configuring your Cisco VPN client with the correct Gateway IP, vpn group and password.
The below link gives a bunch of options accroding to your situation.
http://cisco.com/en/US/products/sw/secursw/ps2308/prod_configuration_examples_list.html
I hope it helps .. please rate it if it does !!!
