outlook encryption plugin
denisp_ironport
Guys , when we install encryption plugin in outlook what configuration we should do on C series , what filter ...?
I try to look on support portal couldn't find anything .
Use a contentfilter for outgoing, check for this in SUBJECT: [SEND SECURE]
You could even add Outlooks own sensitivityflag there and trigger on that as well...
Then have encrypt & deliver as final action.
(remember to enable the contentfilter for outgoing mailpolicy)
Should look something like this:
1 Subject Header subject == "^[SEND SECURE]"
2 Other Header header("Sensitivity") == "Company-Confidential"
Guess this should be moved to c-series or?
:D
I've set up this content filter as described here, however, when I enable it ALL email sent is encrypted, not just email that has [SENT SECURE] in the subject. What am I missing?
