quick static route question
Feb 26th, 2008
my server folks want their ftp server
to use a specific route...this is the only device they want to use this path
if the ftp server on the far end is
would my static route be
If 4.3 is the path to be taken.
i would use all 255 subnet for this
particular route to this particular device...correct?
Jon Marshall Tue, 02/26/2008 - 12:22
It's not entirely clear where you are applying the route ? is it on a server or on a router.
means to get to host send the packet to Yes you would if you just want to specify a destination host.
nygenxny123 Tue, 02/26/2008 - 13:01
yes..the route is for one specific host...
the configuration entry would be on the router,,
so all 255's?
it looks like it is routing the entire subnet
instead of one device
i only want one device to use this route
Router#sh ip route
Routing entry for, 1 known subnets
Redistributing via eigrp 1
S [1/0] via
Jon Marshall Tue, 02/26/2008 - 13:04
Yes all 255's which specifies it is a host entry rather than a subnet entry.
cisconoobie Tue, 02/26/2008 - 15:50
You need to use a route map that will match the source(ftp server) and set ip next hop (new ip)
