Etherchannel and VLAN interface
Feb 26th, 2008
I have a switchstack of 4 3750's(stack #1) that have been connected to another stack of 3750s(stack #2) for a few months.
I recently created an etherchannel with LACP between the two. Now the management interface on stack #1 isn't accessible for machines plugged into stack #2
My machine is plugged into stack #2
There is another stack(stack #3) that connects via etherchannel to stack #2. Machines plugged into that stack can access the VLAN int on stack #1. As well as machines plugged directly into stack #1
Am I missing something pretty standard? I think there is a trunk config I'm missing?
Any help or suggestions are appreciated.
Jasen
Jason Fraioli Tue, 02/26/2008 - 12:52
the management vlans are the same? same IP subnet?
are you running lacp on both port channels? or is one pagp?
are you trunking on your port channel?
do a "show spanning-tree vlan " and look at the interfaces. Do you see 2 fast ethernet ports or a single port channel?
jtkoebler Tue, 02/26/2008 - 13:09
Yes, Management VLANs are the same. Same IP subnet.
LACP on both port channels.
Yes, I'm trunking on the port channel
A Single Port Channel is shown in the 'show spanning-tree vlan
Edison Ortiz Tue, 02/26/2008 - 14:42
  • Hall of Fame,
    Founding Member
Please post show ether sum from both switches.
__
Edison.
jtkoebler Wed, 02/27/2008 - 09:06
Stack #2:
Number of channel-groups in use: 2
Number of aggregators: 2
Group Port-channel Protocol Ports
1 Po1(SU) LACP Gi1/0/49(P) Gi3/0/49(P)
2 Po2(SU) LACP Gi1/0/50(P) Gi2/0/1(P) Gi4/0/1(P) Gi4/0/2(P)
Stack #1:
Number of channel-groups in use: 1
Number of aggregators: 1
2 Po2(SU) LACP Gi1/0/25(P) Gi2/0/25(P) Gi3/0/25(P)
Gi4/0/25(P)
Edison Ortiz Wed, 02/27/2008 - 14:06
  • Hall of Fame,
    Founding Member
Port-channels look good, let's see the config from the 3 stacks.
__
Edison.
jtkoebler Thu, 02/28/2008 - 14:11
Attached are the port-channel and int configs from the 3 stacks.
Initially I noticed that stackone did not have 'switchport mode trunk' under the port-channel command. When added, the problem was not solved.
Stackthree has some configs under gig1/0/1 that a co-worker entered through CNA. I doubt that has any bearing on the issue since everything on that switch is functioning.
Again, thank you all for your assistance. Please let me know if I can provide anything else.
Jasen
Edison Ortiz Thu, 02/28/2008 - 15:40
  • Hall of Fame,
    Founding Member
That's not a good sign. Any changes on the physical interfaces will be mirrored to the logical port-channel interface. I don't recommend making changes in the logical interface. To re-sync the physical with the logical please execute the following commands in stackone (please do it during a maintenance window).
no interface Port-channel2
default interface GigabitEthernet1/0/25
default interface GigabitEthernet2/0/25
default interface GigabitEthernet3/0/25
default interface GigabitEthernet4/0/25
channel-group 2 mode active
Can you also please the output from typing show ip interface brief | ex una from the 3 stacks.
HTH,
__
Edison.
jtkoebler Mon, 03/10/2008 - 11:48
Sorry for the late post, I was out last week.
SWSTMAD01#show ip int br | ex una
Vlan1 192.168.172.228 YES manual up up
SWSTMAD02#show ip int bri | ex una
Vlan1 192.168.172.246 YES manual up up
Vlan173 192.168.173.2 YES manual up up
Vlan174 192.168.174.1 YES manual up up
SWSTMAD03#show ip int br | ex una
Vlan1 192.168.172.242 YES NVRAM up up
Again, thank you for your help. Please let me know if I can provide any other information.
Jasen
Mohamed Sobair Wed, 02/27/2008 - 13:19
  • Gold, 750 points or more
In order for ports to successffuly negotiate Ether channel some criteria must match:
1- spanning-tree config.
2- Vlans allowed.
3- Port Speed and duplex.
4- Ether channel type. (LACP or PAGP).
if its LACP standard, then make sure one part of the ether channel is active, this will allow ports to initiate negotiate LACP with its peer.
this would acheived by:
channel-group (Port channel number) mode active -- this is Interface Config command.
Mohamed
