Any Connect VPN
Answered Question
Feb 26th, 2008
When I connect to our AnyConnect VPN, I am not able to get out to the internet. Is there any settings on our ASA5520 that need to be checked in order for this to work.
Correct Answer by rico_hao40 about 9 years 3 weeks ago
I use split-tunnel tospecify the subnet need go through vpn tunnel, and all other traffic go through regular way (no vpn tunnel). That means when you connect to vpn, it download routes (subnets) need to be tunneled through vpn.
You can search "vpn split-tunnel" to find an example.
Overall Rating: 4 (1 ratings)
Correct Answer
rico_hao40 Tue, 02/26/2008 - 17:05
