UC500 Meet-Me CLI configuration...
Feb 26th, 2008
Does anyone know how to configure a meet-me conference on a UC500 via the CLI? The configuration notes for CME 4.2 don't seem to apply, since the UC500 does not have the required dspfarm pool. I would appreciate any help! Thanks, Dennis.
Overall Rating: 4.5 (2 ratings)
paolo bevilacqua Tue, 02/26/2008 - 13:49
  • Hall of Fame,
    Founding Member
Meet-me must use dspfarm, why do you say that is not in the uc500? Don't you see two voice-cards in config ?
dmorassut-sbi Tue, 02/26/2008 - 14:48
Thank you for your reply.
I'm new to the UC500 and CME platform in a lot of ways (coming from full server-based CallManager), so I might be missing something here. This is what I see from the command line:
Before Config:
#sh dsp
DSPFARM Configuration Information:
Admin State: DOWN, Oper Status: DOWN - Cause code: ADMIN_STATE_DOWN
Transcoding Sessions: 0(Avail: 0), Conferencing Sessions: 0 (Avail: 0)
Trans sessions for mixed-mode conf: 0 (Avail: 0), RTP Timeout: 600
Connection check interval 600 Codec G729 VAD: ENABLED
Config (start):
dsp services dspfarm
After Config:
#sh dspfarm ?
all Display all DSPFARM global info
dsp Display DSPFARM DSPs information
profile Display DSPFARM profiles
#sh dspfarm all
Total number of DSPFARM DSP channel(s) 0
#sh dspfarm dsp active
Am I on the right track?
Dennis.
paolo bevilacqua Wed, 02/27/2008 - 11:09
  • Hall of Fame,
    Founding Member
Here's the config I use in a customer install, to support 2 x 8 parties G.711 conferencing only. There is only one set of ephone-dn for conference configured. The remember to cofngire the meet-me softkey in ephone-template.
voice-card 0
dspfarm
voice-card 1
no dspfarm
! recommend use of loopback
sccp local Loopback0
sccp ccm 10.6.4.200 identifier 6200 version 4.0
sccp
sccp ccm group 100
bind interface GigabitEthernet0/0.4
associate ccm 6200 priority 1
associate profile 10 register confdsp1
dspfarm profile 10 conference
codec g711ulaw
maximum sessions 2
associate application SCCP
telephony-service
sdspfarm units 1
sdspfarm tag 1 confdsp1
conference hardware
ephone-dn 192 dual-line
number 693
conference meetme
no huntstop
ephone-dn 193 dual-line
number 693
conference meetme
preference 1
no huntstop
ephone-dn 194 dual-line
number 693
conference meetme
preference 2
no huntstop
ephone-dn 195 dual-line
number 693
conference meetme
preference 3
dmorassut-sbi Wed, 02/27/2008 - 12:21
Thank you very much for this. I will give it a try and let you know how I make out.
Dennis.
dmorassut-sbi Tue, 08/19/2008 - 10:21
Picking this up again after some time and for a different customer location... this config really did help. Thank you.
mpitts Tue, 09/09/2008 - 09:37
Paolo,
This configuration also helped me, with a problem I had with the dspfarm not registering with SCCP on a UC500, except that I am using multi-party ad-hoc instead of meet me conference.
Everything now looks fine but when the folks press the Confrn softkey they get a message "no line available". The only thing I haven't tried is resetting the entire system.
I've attached the whole configuration in case there is something I've missed, but I think I have covered everything I could find in the documentation. If you could look through it when you have the time I would appreciate it.
Mike
