Can't assign SSL certificate to a configured Trustpoint
Feb 26th, 2008
I created a trustpoint and submitted a CSR to my CA (Entrust). (ASA 5520 with OS 7.2(2)27. I followed the "PIX/ASA Manually Install 3rd Party Certificate" document from the Support site. After receiving the signed cert, I followed the instructions but cannot associate the cert with the Trustpoint that I created. In the Pull down list, there is only a selection of "None". Any help would be appreciated on this problem.
tomek0001 Tue, 02/26/2008 - 13:21
I have the same problem. I'm not sure why but when you do a self signed cert you can see that as an option to add to SSL.
I'm using ASA5510 version 8.0 with windows 2003 CA.
tomek0001 Tue, 03/04/2008 - 18:49
I'm not sure if you did this but did you add the root certificate of the CA that you are trying to get your key signed?
I think that's what my problem was. You need to have the root cert imported first I believe.
(please rate if you found this post useful)
