H-REAP Question
Feb 26th, 2008
I have a question about H-REAP. I'm using a 4402 with 10 1231 APs and two SSIDs (guest and staff). I'm expanding wireless to some of my other sites and want to use H-REAP with local switching. The APs going into the remote sites are 1241s so they do support H-REAP.
If I tell configure my staff SSID for H-REAP local switching, will the 10 older 1231 still central switch the SSID since they do not support H-REAP? Or will they just fail to work with that SSID?
Patrick
hypnotoad Wed, 02/27/2008 - 11:00
Thanks for the information. I did a test last night and was able to have the same SSID work with H-REAP and central switching.
--Patrick
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
