02-26-2008 05:00 PM - edited 03-05-2019 09:24 PM
Quick question regarding secondary IP Addresses...
I have a customer who has multiple gateways per vlan across a couple switches (don't ask). In order to help migrate them with a more seamless transition to the new network I'm installing for them, I was wondering about secondary addresses. If I create an SVI for say, vlan 100. Could I put secondary addresses on it which can also be used as gateway for that network?
ex
Interface vlan100
ip address 1.1.1.1 255.255.255.0
ip address 1.1.1.2 255.255.255.0 secondary
Could both of those be used as gatways if I have 10 machines set as 1.1.1.1 as the gateway and 10 others set to 1.1.1.2?
Scott
02-26-2008 05:43 PM
Yes you can do that...
02-26-2008 06:31 PM
Thank you for your reponse, something else to add...can I use HSRP with this set up?
interface vlan 100
ip address 1.1.1.3 255.255.255.0 secondary
ip address 1.1.1.4 255.255.255.0
no ip redirects
standby 100 ip 1.1.1.1
standby 100 priority 110
standby 100 preempt
or
interface vlan 100
no ip redirects
standby 100 ip 1.1.1.2 secondary
standby 100 ip 1.1.1.3 secondary
standby 100 preempt
Thanks again,
Scott
02-26-2008 07:38 PM
Scott
I certainly agree with Glen that your first question would work. In this post your option 1 with a primary, several secondaries, and an HSRP address would certainly work. And it would give you some flexibility to migrate end stations which are configured with .2 or .3 or .4 as their gateway to be configured with .1 as the gateway.
(as a side note I am not sure why you are setting priority 110. perhaps if we had more context of what you are configuring it would make better sense. but my immediate reaction to priority 110 is that if you are doing track interface with default values it will decrement to priority 100 and create a tie with the standby interface which will not allow the standby interface to take over. I much prefer priority 105.)
I am not sure that your option 2 with a single configured address and with multiple secondary addresses in HSRP would work. I do not know that it would not. But I suspect that there are problems with it.
Rick
02-26-2008 08:03 PM
Thanks Rick...this is how I would have both routers set up.
Option 1
interface vlan 100
no ip redirects
standby 100 preempt
interface vlan 100
ip address 1.1.1.5 255.255.255.0 secondary
ip address 1.1.1.6 255.255.255.0 secondary
ip address 1.1.1.7 255.255.255.0
no ip redirects
standby 100 priority 100
standby 100 preempt
Option 2
interface vlan 100
no ip redirects
standby 100 ip 1.1.1.5 secondary
standby 100 ip 1.1.1.6 secondary
standby 100 ip 1.1.1.7 secondary
standby 100 ip 1.1.1.8 secondary
standby 100 preempt
interface vlan 100
no ip redirects
standby 100 preempt
I'm wondering which would be the best way to migrate the users...and seamlessly begin to remove the secondary IPs once everyone is migrated. It seems to me that option 2 (If it's possible) would be the best for true redundancy.
Thanks again,
Scott
02-27-2008 05:09 AM
Scott
I have no doubt that option 1 would work. I have not seen option 2 where you define a secondary HSRP group but no secondary address. I have seen configs with a secondary address and a secondary HSRP group but not the secondary group without a secondary address configured. It might work - I just am not sure. It would be a good thing to create a test environment for and check it out.
I can see that it would provide redundancy. But I am not clear what IOS does when it has a secondary HSRP group but no secondary address. I wonder if you would need something like this:
interface vlan 100
ip address 1.1.1.9 255.255.255.0 secondary
ip address 1.1.1.10 255.255.255.0 secondary
ip address 1.1.1.11 255.255.255.0 secondary
ip address 1.1.1.12 255.255.255.0 secondary
ip address 1.1.1.13 255.255.255.0 secondary
no ip redirects
standby 100 preempt
Rick
