CSM 3.0 Deployment
ASA5200 firewall had been deployed and live. The configuration is done via ASDm and also CLI.
Now CSM is deployed to the network, and discovery of the firewall is work and able to pull all the existing config fom firewall.
Previously let say I had access-list name ACL_TEST1 and apply to interface outsite.
When I pull it from CSM, the access rule do not show the access-list name. It just purely indicate the access rules is apply to which interface.
If I change the access rule at CSM and deploy it to firewall.
What do us expected in firewall configuration ? The access-list name ACL_Test remain or CSM will change the access-list name based on CSM system default assign name ?
Is there any downtime when deploy via CSM ?
ivillegas Mon, 03/03/2008 - 14:12
  • Silver, 250 points or more
If only the access rules are changed CSM will deploy the ACL-Test to ASA.
