backup and restore ACS
Feb 26th, 2008
i have a ploblem: i backup database from ACS SE 4.0, after import that database into ACS Window 4.0 and upgrade ACS window 4.0 to 4.1. Backup database from ACS window 4.1 and import it into ACS SE4.1, after restore database into ACS SE 4.1 TACACS service is runing nomal but RADIUS is not running, what is erro??
ducnv
thanks
jbayuka Tue, 03/04/2008 - 07:36
  • Bronze, 100 points or more
The ACS Backup feature provides the option to back up your user and group databases, and your ACS system configuration information to a file on the local hard drive. You can manually back up the ACS system. You can also establish automated backups that occur at regular intervals, or at selected days of the week and times. Maintaining backup files can minimize downtime if system information becomes corrupt or is misconfigured. We recommend copying the files to the hard drive on another system in case the hardware fails on the primary system.
Refer to http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.0/user/guide/sba.html#wp222373 for more information
