VPLS Setup Problem
Feb 26th, 2008
Hi, I am trialling VPLS with BGP autodiscovery, using the configs supplied at http://www.cisco.com/en/US/docs/ios/mpls/configuration/guide/mp_vpls_auto_bgp.html
AND
http://www.cisco.com/application/pdf/en/us/guest/tech/tk891/c1482/ccmigration_09186a00801ed3ea.pdf
Using these templates, I am still unable to pass traffic between the endpoints.
Here is some show command output:
PE1_7604#sh mpls l2transport vc 24 det
Local interface: VFI VPLS-1 VFI up
MPLS VC type is VFI, interworking type is Ethernet
Destination address: 10.0.2.1, VC ID: 24, VC status: up
Output interface: none, imposed label stack {17}
Preferred path: not configured
Default path: active
Next hop: Invalid ADDR
Create time: 00:55:10, last status change time: 00:00:29
Signaling protocol: LDP, peer 10.0.2.1:0 up
Targeted Hello: 10.0.1.1(LDP Id) -> 10.0.2.1
MPLS VC labels: local 19, remote 17
AGI: type 1, len 8, 000A 4773 0000 0018
Local AII: type 1, len 4, 0A00 0101 (10.0.1.1)
Remote AII: type 1, len 4, 0A00 0201 (10.0.2.1)
Group ID: local n/a, remote n/a
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, send 0
PE1_7604#sh mpls forwarding-table
Local Outgoing Prefix Bytes Label Outgoing Next Hop
Label Label or VC or Tunnel Id Switched interface
17 Pop Label 10.0.2.1/32 0 Gi2/48 172.16.1.2
18 No Label l2ckt(25) 0 none point2point
19 No Label l2ckt(24) 0 none point2point
As you can see, my outgoing interface is "None" and my next hop is "Invalid ADDR". I suspect this is the problem, but can't fix it.
blakeovich Thu, 03/13/2008 - 17:10
The uplink is not a port channel.
TAC have responded by saying that VPLS is only supported on the OSM-type interfaces?
We planed on using the uplink ports on our Sup720-3BXLs.
Harold Ritter Tue, 03/25/2008 - 06:50
Blake,
VPLS does indeed require that the core facing interface is either part of a SIP, ES or OSM card.
