Conferencing on PVDM2-8
Feb 27th, 2008
I am trying to configure a conference bridge on a 2801 router, with a PVDM2-8.
No FXOs or FXSs are installed on this router.
The scenario I am trying is connecting from an IP Phone to a PSTN phone. Then calling another IP Phone in the LAN then trying a conference. The initiator's screen shows "Can not complete conference" and the PSTN call is dropped, sustaining only the call between the 2 IP Phones.
I have a callmanager 4.1, I created the Enhanced IOS conference Bridge, it's registered fine. I put this conference bridge in the MRG and the phones with the proper device pool and MRGL.
ROUTER#!
voice-card 0
dsp services dspfarm
sccp local FastEthernet0/0
sccp ccm 192.168.0.34 identifier 1 version 4.0
sccp
sccp ccm group 1
associate ccm 1 priority 1
associate profile 1 register HWCONFBRIDGE
dspfarm profile 1 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
maximum sessions 1
associate application SCCP
ROUTER#sh dspfarm all
Dspfarm Profile Configuration
Profile ID = 1, Service = CONFERENCING, Resource ID = 1
Profile Description :
Profile Admin State : UP
Profile Operation State : ACTIVE
Application : SCCP Status : ASSOCIATED
Resource Provider : FLEX_DSPRM Status : UP
Number of Resource Configured : 1
Number of Resource Available : 1
Codec Configuration
Codec : g711ulaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g711alaw, Maximum Packetization Period : 30 , Transcoder: Not Required
Codec : g729ar8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729abr8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729r8, Maximum Packetization Period : 60 , Transcoder: Not Required
Codec : g729br8, Maximum Packetization Period : 60 , Transcoder: Not Required
SLOT DSP VERSION STATUS CHNL USE TYPE RSC_ID BRIDGE_ID PKTS_TXED PKTS_RXED
0 1 1.1.1 UP N/A FREE conf 1 - - -
Total number of DSPFARM DSP channel(s) 1
ROUTER#sh sccp
SCCP Admin State: UP
Gateway IP Address: 192.168.0.1, Port Number: 2000
IP Precedence: 5
User Masked Codec list: None
Call Manager: 192.168.0.34, Port Number: 2000
Priority: N/A, Version: 4.0, Identifier: 1
Conferencing Oper State: ACTIVE - Cause Code: NONE
Active Call Manager: 192.168.0.34, Port Number: 2000
TCP Link Status: CONNECTED, Profile Identifier: 1
Reported Max Streams: 8, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: g711alaw, Maximum Packetization Period: 30
Supported Codec: g729ar8, Maximum Packetization Period: 60
Supported Codec: g729abr8, Maximum Packetization Period: 60
Supported Codec: g729r8, Maximum Packetization Period: 60
Supported Codec: g729br8, Maximum Packetization Period: 60
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
I did a couple of reloads even restarted the callmanager.
Is it an IOS issue? or a misconfiguration?
Can anyone help me out in this?...
Ahmed El-Eraky
Overall Rating: 5 (1 ratings)
paolo bevilacqua Wed, 02/27/2008 - 02:18
  • Hall of Fame,
    Founding Member
Hi, which exact IOS are you using ?
paolo bevilacqua Wed, 02/27/2008 - 06:44
  • Hall of Fame,
    Founding Member
Can you try 12.4(3j) that is the most stable ?
AhmedEl-Eraky Wed, 02/27/2008 - 07:52
Thank you for your response.
I did as you've suggested but still no luck.
same exact behavior, the message still appears.
I can't seem to find any problems with my configuration, I rechecked. Each side (the router's and the callmanager's) seem to be fine by itself. But it still isn't working together.
Do you have any ideas?...
Thanks....
Ahmed El-Eraky
Michael Owuor Wed, 02/27/2008 - 08:19
  • Cisco Employee,
If you have CCM traces collected at the time the test is performed, they may give further insight into the cause of the problem. For example it could be that the CFB is allocated but there's insufficient bandwidth to connect one of the conference call participants, maybe due to Locations configuration. Or perhaps a different CFB resource is being allocated than the one we expect. Either way, if you can collect the CCM SDI traces, and search for 'Can not Complete Conference', then the lines of traces just before that will likely point to a definitive cause of the problem. Attach those traces here if need be.
Michael.
Jaime Valencia Thu, 02/28/2008 - 07:56
  • Cisco Employee,
  • Hall of Fame,
    2011
Check the MRGL from the conference initiator to have in 1st place the HWCFB.
If you have in 1st place a SW CFB you will try to use it and the conference will drop, CCM won't go thru any other CFB to try the conference. In the best scenario the SW CFB would reach for a XCODER.
AhmedEl-Eraky Thu, 02/28/2008 - 12:28
Hello everyone....
It worked.... I just didn't get the chance to feedback you guys....
Not one thing in the configuration was changed. I double checked all of the configuration then I simply restarted everything, the router, the CCM, even resetted the IP Phones. Not sure exactly what was wrong!!...
but anyway thank you all for your support. Appreciate the help.
Ahmed El-Eraky
