**ERROR**: host_incoming_call: Received a call with a bad bearer cap
Answered Question
Feb 27th, 2008
I have a 1700 running Version 12.2(8)YN, acting as a voice gateway with ISDN BRI lines.
Everything works find, and it has been running for years without a problem.
Now, when I try and divert calls from a Mobile to my ISDN DDI, I get the above error message.
A ISDN debug is as below
Both called and calling part numbers show up correctly ! (I have xxxx them out)
The BRI Config is as below
interface BRI2/0
description BT line
no ip address
no logging event link-status
isdn switch-type basic-net3
isdn incoming-voice voice
isdn map address .* plan unknown type unknown
isdn static-tei 0
interface BRI2/1
no ip address
isdn static-tei 0
*Mar 15 22:22:35.732: ISDN BR2/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x9090A3
Standard = CCITT
Transer Capability = 3.1kHz Audio
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x89
Facility i = 0x91A1240202400002010F301B0201010A0100A113A011A10F0A0102120A37393434303335313730
- ETSI Supplementary Service, Invoke, Diverting leg 2
Progress Ind i = 0x8483 - Origination address is non-ISDN
Calling Party Number i = '!', 0x83, 'xxxxxxxxxx'
Plan:ISDN, Type:National
Called Party Number i = 0x81, 'xxxxx'
Plan:ISDN, Type:Unknown
*Mar 15 22:22:35.736: ISDN BR2/1 **ERROR**: host_incoming_call: Received a call with a bad bearer cap from <unknown> on B1
*Mar 15 22:22:39.718: ISDN BR2/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Standard = CCITT
Channel ID i = 0x89
Calling Party Number i = '!', 0x83, 'xxxxxxxxx'
*Mar 15 22:22:39.722: ISDN BR2/1 **ERROR**: host_incoming_call: Received a call with a bad bearer cap from <unknown> on B1
*Mar 15 22:22:43.625: ISDN BR2/1 Q931: RX <- DISCONNECT pd = 8 callref = 0x01
Cause i = 0x82E6 - Recovery on timer expiry
*Mar 15 22:22:43.625: ISDN BR2/1 Q931: L3_Go: L3_GetUser_NLCB returned NULL cid 0x0 cr 0x81 ev 0x45 ces 1 -- Message ignored
*Mar 15 22:22:43.629: ISDN BR2/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x81
Cause i = 0x80D1 - Invalid call reference value
For a normal call, the ISDN is as below
*Mar 15 22:43:55.798: ISDN BR2/1 Q931: RX <- SETUP pd = 8 callref = 0x01
Sending Complete
Bearer Capability i = 0x8090A3
Standard = CCITT
Transer Capability = Speech
Channel ID i = 0x89
Calling Party Number i = '!', 0x80, 'xxxxxxx'
Called Party Number i = 0x81, 'xxxx'
Obviously the bearer capability is causing the problem, but I cant seem to figure out how to fix it !!
I tried setting bearer-cap speech and 3100hz on the BRI voice ports, but that does not seem to help !!
Any idea how I can fix this ??
Correct Answer by smvoicerite about 9 years 2 months ago
Just wanted to flag this issue as resolved
Overall Rating: 5 (1 ratings)
shahedvoicerite Wed, 02/27/2008 - 05:59
After I upgraded the IOS to 12.3, I now get :-
Rejecting call, calltype screening failed
I am translating the calling number on the Voice Port, but I have
translation-rule 90
Rule 0 ^0 900 ANY unknown
and
So, I cant understand what the problem may be.
Any ideas ?
shahedvoicerite Wed, 02/27/2008 - 06:07
Actually the IOS upgrade solved my problem.
I had made some chages to the config, that rejected 3100hz audio and did not realise it was still there !!
Correct Answer
smvoicerite Wed, 02/27/2008 - 06:11
