how to prevent local aaa users to login
Feb 27th, 2008
Hi!
Please could you help me with my question:
My Cisco router R1 aaa configuration:
username user1 privilege 15 password user1
username user2 password user2
aaa authentication login default local
aaa authorization exec default local
aaa authentication ppp PPP_MODEM local
aaa authorization network PPP_MODEM local
So, I want to:
allow user1 to have full terminal access to R1
deny user2 to have any terminal access to R1 but allow user2 to connect to R1 via PPP.
I can configure privilege 0 to user2, but user2 will be able to access R1 terminal lines!
How can I prevent user2 to have management access to R1 using only local AAA services?
jsivulka Tue, 03/04/2008 - 10:04
  • Bronze, 100 points or more
It is set to No Privilege by default. Set this to use group level settings. You also have to configure the enable password for the user
Here is a copy of my AAA settings:
aaa new-model
aaa authentication login default tacacs+ enable
aaa authentication login no_tacacs enable
aaa authentication enable default tacacs+ enable none
aaa authorization exec default tacacs+ if-authenticated
aaa authorization commands 7 default tacacs+ local
aaa authorization commands 15 default tacacs+ local
aaa accounting exec default start-stop tacacs+
The method no_tacacs is used for the console to prevent admin-lockouts. Doing a debug aaa authen & author was quite helpful in getting this to work.
