Caller_ID problem
I have a problem when receiving incoming call. The router strips the leftmost digit (0) off and present only the last 10 digits. for example when caller (0123465245) calls, only 123465245 appears on the cisco IP phone.
Can somebody advice me on what needs to be configured on the callmanger router to rectify this issue.
The following are the configs for the VOIP. I have also attatched Debug isdn 931 and sh trunk group outputs
trunk group Outgoing
translation-profile incoming addzero
voice translation-rule 300
rule 1 // /0/ type national national
rule 2 // /00/ type international international
voice translation-profile addzero
translate calling 300
dial-peer voice 150 voip
destination-pattern 5...
session protocol sipv2
session target ipv4:192.168.0.253
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 151 pots
description Incoming calls on BRI 0/0/0
incoming called-number .
direct-inward-dial
port 0/0/0
dial-peer voice 100 voip
dial-peer voice 152 pots
description Incoming calls on BRI 0/0/1
direct-inward-dial
port 0/0/1
Paolo Bevilacqua Wed, 02/27/2008 - 04:42
Hi, all seems configured correctly.
Can you try placing the voice translation-profile addzero, for incoming, directly under the voice-port.
Paolo Bevilacqua Wed, 02/27/2008 - 10:38
Ok, can you try:
rule 1 // /0/ type national national plan isdn isdn
I have this setup in many install and it has always worked ?!?
