marikakis Wed, 02/27/2008 - 06:29
Check out if the URL below applies to you. This will depend on the particular MGX model you have and which Release. Read the Introduction to see if this is the release of documentation that applies to your case. If it doesn't, then you could try searching in cisco.com for a similar document for your particular needs.
http://www.cisco.com/en/US/docs/switches/wan/mgx/mgx_8850/software/mgx_r5.2/data/pnni/network/planning/guide/pintro.html
Kind Regards,
M.
