Using Multidirectory
Feb 27th, 2008
I have two diferente cluster running 5.1.2, i have installed sdk 4.1 for use the multidirectory.asp to integrate the two dc directory on a singel search. Can any one tell me wath fields do i have to change in multidirectory.asp to point the search into the two clusters.
Many thanks
Overall Rating: 1 (1 ratings)
stephan.steiner Thu, 02/28/2008 - 06:49
  • Silver, 250 points or more
You realize that CCM 5 is Linux .. so it's goodbye to ASP (and DC directory for that matter.. it's all in an informix database now). You'll have to write your own directory this time around using AXL to access to the database on the callmanager.
