!!! PDLM problems on 7200 !!!
Feb 27th, 2008
I have a TAC case open on this but I thought I would float it here, too.
IOSver advipservices 12.4.11T
platform 7200/NPE-G1
I am adding a pdlm for sap-app on a 7200.
when the pdlm is loaded (other than at boot time) some very bad things happen.
The symptom is that my configuration changes. e.g. in an existing class-map, a config line that previously said "match protocol eigrp" now says "match protocol ipinip"
I suspect that that nbar keeps a table of protocols in memory and adding the new pdlm causes the index to change resulting in these symptoms.
Anyone else seen this? If it is a known bug is there a code version where it is fixed?
Overall Rating: 1 (1 ratings)
Mohamed Sobair Fri, 02/29/2008 - 11:02
Yes, PDLMs are installed in a flash memory, Cisco routers and Switches do recognize PDLMs by looking into the Payload of the Data at the layer-3 header.
I am not exactly sure about this symbtoms, but it's strange because it identifies the application signature rather than TCP/IP port number.
Pls let us know the feedback from TAC,
john.dean Wed, 06/11/2008 - 10:50
DE made the situation worse by ignoring it...
Same bug has now surfaced on the 2800 platform in code c2800nm-advipservicesk9-mz.124-15.T4.bin.
I assume 3800 is similarly affected.
