cat 6500 with csm
Feb 27th, 2008
When I enter the command: clear module contentSwitchingModule 2 counters
the value: Connections Current: 30713 does not reset. What I have to do to reset this value, is it normal that it does not reset?
pknoops Wed, 02/27/2008 - 08:46
  • Bronze, 100 points or more
What version of code is the CSM running ?
Pete..
mauricebar Fri, 02/29/2008 - 06:07
Hi the version is: 1.1(3) as shown in the show module command output.
Maurice
pknoops Fri, 02/29/2008 - 06:28
Hi Maurice,
I believe that is the HW rev and not the Software version of the CSM.
Just verify the show module output. The first number is the HW rev and the second is the SW rev like this:
7 0015.f998.a83a to 0015.f998.a841 1.8 <-- HW 4.1(5) <--SW Ok
In any event, you are probably hitting bug id CSCsd07524.
Pete..
mauricebar Fri, 02/29/2008 - 08:03
Hi Pete, this is the output of the command:
CSUIORTP02#sh module
Mod Ports Card Type Model Serial No.
1 48 48 port 10/100/1000mb EtherModule WS-X6148-GE-TX SAL1106GMAB
2 4 CSM with SSL WS-X6066-SLB-S-K9 SAD1113027E
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAL1050AY20
6 2 Supervisor Engine 720 (Hot) WS-SUP720-3B SAL1052BZ1W
Mod MAC addresses Hw Fw Sw Status
1 0019.304b.6020 to 0019.304b.604f 7.1 7.2(1) 8.5(0.46)ROC Ok
2 001a.a148.8f8a to 001a.a148.8f91 1.3 1.1(3) Ok
5 0013.c347.6650 to 0013.c347.6653 5.3 8.4(2) 12.2(18)SXE6 Ok
6 0016.c847.cfac to 0016.c847.cfaf 5.3 8.4(2) 12.2(18)SXE6 Ok
Mod Sub-Module Model Serial Hw Status
5 Policy Feature Card 3 WS-F6K-PFC3B SAL1050AT88 2.3 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL1050AY6R 2.6 Ok
6 Policy Feature Card 3 WS-F6K-PFC3B SAL1051BQS0 2.3 Ok
6 MSFC3 Daughterboard WS-SUP720 SAL1052BZW8 2.6 Ok
