Interface State
eugene.fourie
Does anyone know why the interface is showing "reset" for layer 1 on a serial interface? I have removed the interface from the T1 controller and setup the interface again and have no cable plugged into the port, yet the device still states layer 1 is in "reset" indefinitely.
lamav
Level 8
Level 8
can you post the output of a show interface fo rthat interface?
Victor
#sh int s2/0:0
Serial2/0:0 is reset, line protocol is down
Hardware is M32X with CSU/DSU
MTU 1500 bytes, BW 1536 Kbit, DLY 20000usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Last input never, output never, output hang never
Last clearing of "show interface" counters 11:35:22
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/0/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
Available Bandwidth 1152 kilobits/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
0 carrier transitions
Timeslot(s) Used:1-24, Transmitter delay is 0 flags
