Adding IP routing address
Feb 27th, 2008
I am using a PIX ASA5500 network appliance. And I am using the ASDM software to configure it. My question should be simple to answer.
I have an "example" 192.168.0.1/24 255.255.255.0 I am out of IP address and I need to add more I would like to add 192.168.1.1/24 255.255.255.0 and 192.168.2.1/24 255.255.255.0.
Can someone please help with this it has to easy to do I just don't know how and this is my first router I have ever had to setup.
PS and I am worthless at the command line interface.
noroutes4u Wed, 03/05/2008 - 12:40
Are you trying to add more address to use in your global nat or are you adding another interfaces to use those address?
jaipal Mon, 04/07/2008 - 00:31
It will be too complicated while on trouble shooting any issues, you can try a class B subnet to over come this issue.
Rick Morris Wed, 04/09/2008 - 06:32
  • Silver, 250 points or more
change your netmask
To allow for 192.168.0.0 - 192.168.3.255 use 255.255.252.0
