02-27-2008 09:57 AM - edited 03-15-2019 09:06 AM
Last night I upgraded a CCM 4.1(3) to SR6. I also updated BARS to 4.0(13). There were some problems with BARS so I ended up uninstalling it from the Master and from the Target and then reinstalling it fresh on both servers.
Since then I've been getting the following error in the event logs:
Source - SQLSERVERAGENT
Category - Job Engine
Event - 208
SQL Server Scheduled Job 'Monitor Disk Space' (0xA95C14072AD59F4AA1F111DCD488A4F4) - Status: Failed - Invoked on: 2008-02-27 02:00:02 - Message: The job failed.
The Job was invoked by Schedule 21 (Schedule 1). The last step to run was step 2 (TruncateCCMLog).
I found Bugs CSCsc55053 & CSCsg32819, but they aren't for 4.0(13). Anyone have any ideas? Thanks!
02-27-2008 10:19 AM
Hi Mike,
Have a look at this thread from about a year ago. There is a really nice fix from Jorge @ AT&T;
Hope this helps!
Rob
02-27-2008 10:26 AM
Those 2 fixes are the ones listed in the bugs I referenced. I already checked both fixes and my system appears to be fine. The correct database name is listed in the scripts and Administrator is the owner of the database.
Any other ideas?
02-27-2008 10:35 AM
After reading the next post down in that other thread, it said to check the CDR database too. It is showing the owner as Unknown so that may be my problem.
Does running sp_changedbowner '
also work to set the permssions for the CDR database? Thanks!
02-27-2008 04:13 PM
Can anyone confirm the command to reset the owner for the CDR database? Thanks!
02-28-2008 05:57 AM
Hi Mike,
Sorry for the delay :) I did find another post that does confirm that this is the correct command;
Hope this helps my friend!
Rob
