ipsec peer local port / remote port
fmasson
showing active crypto sessions shows peer ip address and port 500.
Theres a clear crypto session command where i can choose port (default is 500), so my question is if i also could assign a specisic port to a cryptop map / profile.
background is if it's possible to have more than one ipsec tunnel active between the same peer ip addresses.
regards
Frank
parvees123
Frank,
NO , ther will be only one L2L tunnel between two peers. But multiple IPSEC proxies ( IPSEC sa) can be generated . But tunnel wise yes only one!!!
PLease dont forget to rate me!!
hth,
Parvees
